Ansys Products
Ansys Products
MotorCAD: How to export simulation results?
    • Be Ru
      I am interested in the flux density changing over time through the magnets. Therefore, I set up a simple simulation in motorcad and also get a neat animation of the result in the E-Magnetics tab. However, I am now struggeling to export the corresponding data of the flux density in the magnet shown in the gif below. I need something like a vector field in a .csv-file for each time step or similar...Is this possible?
    • Timos
      Hello, it is possible to export flux density on a rotating point, line or arc. Firstly you should create the rotating path and the desired expression in E-Magnetics>FEA Paths. Afterwards, you should click on Help>Graph Viewer. In the Graph Viewer window, click in Graph editor>select Series>Data.
      You can find more information in Help>Tutorials>FEA_Path_Measurement.
    • Be Ru
      Hi!
      Can I add such fea paths or rather points also via a script? I need quite a lot of them so it would be helpful to automate it.
