May 12, 2023 at 5:06 pm
MD KHALID MAHMUD BIN AZAM
SubscriberI can add additional input parameters in optiSLang by altering the python script.
But I can't do the same for output parameters.
Why so?
May 17, 2023 at 2:55 am
HDLI
Ansys EmployeeHello MD KHALID MAHMUD BIN AZAM,
Could you review “OptiSLang_Integrated_Export_Tutorial_Scripting.pdf” to find how to add additional customized output parameters? This tutorial is in MotorCAD installation folder like C:\ANSYS_Motor-CAD\2023_1_2\Tutorials\Ansys_Optislang\IPM using Integrated Export\
Or you could modify the python scripting by yourself. We should export customized output parameters in coupling between MotorCAD and optiSLang.
Thanks.
Howard
May 17, 2023 at 1:32 pm
SubscriberThanks for the reply. I did the same thing using "OptiSLang_Integrated_Export_Tutorial_Scripting.pdf". But it did not work. Adding input parameters works but the output parameters did not. What Can I do ?
May 18, 2023 at 12:38 pm
HDLI
Could you follow the tutorial to complete the example? to verify if you can add output parameters as what the document said.
Please check if the output parameter exists. Thanks.
Howard
May 18, 2023 at 2:01 pm
Subscriberwe tried adding the exact same lines of code from the example in our script.
still, we weren't able to add the output parameter.
- Maxwell, HFSS or Q3D?
- Error
5454
3419
2473
1310
1022
