August 9, 2019 at 9:53 pm
dreamyjyh
SubscriberHello,
I'm trying to change the mouse button assignments, however, even though I change the settings under the "Graphics Interaction" default setting is on.
For example, I deactivated the mouse wheel and middle button and assigned "Rotate" for "Ctrl+Left Button." I restarted the program and tried the new mouse button assignments, but the default setting (rotate with middle button) is still active and no change is made. Is there a way I can fix this issue?
Thank you.
August 12, 2019 at 10:42 am
Ansys EmployeeWhich tool are you using, and which mouse set of mouse settings did you change? Note, staff are not permitted to open/download attachments.
August 12, 2019 at 2:38 pm
dreamyjyh
SubscriberHi,
Discovery AIM 19.2 is is the version I am using. I changed the Mouse Button Assignment as following:
Mouse Wheel: None
Middle Button: None
Shift+Left Button: Box Zoom
Ctrl+Left: Rotate
Ctrl+Shift+Left Button: Multi-Select
Rest of the settings are not changed from the default.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2524
2064
1279
1096
456
