Moving Block from pressure inlet udf
    • pascuan
      I am trying to create a moving block from a pressure inlet. I have set up a dynamic mesh. I do not know how to write my own udf though. Any assistance would be great. Please help.
    • Karthik R
      Administrator
      Please take a look at the Fluent Customization manual. There are several UDF examples you can use as your starting point to write your code. Here is the link
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_udf/flu_udf_DynamicMeshDEFINE.html?q=dynamic
      If you are looking for instructions on how to use this help, please have a look here.
      https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
      I hope this helps.
      Thank you.
      Karthik
    • pascuan
      Hello Karthik,
      I have working udf for the movement of the zone reference for dynamic mesh. However, I would like my moving zone to stop when it contacts with the wall. I get an error when the zone reaches the wall too. I have checked 2.6.6 DEFINE_CONTACT for the details but I cannot interpret the code given. Any assistance would be appreciated. I like learning about CFD Ansys. Thank you for your help so far.
      I have attached my udf and dynamic mesh motion for reference.
      https://drive.google.com/drive/folders/1xPiwE4oRW4Al5Osuv5B5YUTvXu5B_eAj?usp=sharing
    • Karthik R
      Administrator
      Please see if you can use the 'Contact Detection' feature in Fluent for this. Here are the details.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_dynam_sec_set_contact_det.html?q=contact%20detection
      Also, as Ansys employees, we are not able to open any files attached to this community. Just an FYI.
      Thank you.
      Karthik
    • pascuan
      Hi Karthik,
      I have visited the link but am having trouble when using it on Fluent. When i changed the proximity setting to a higher threshold, I believe contact was detected but my program has been interrupted. Every time I run it the program is interrupted and I have to close it through task manager. Thank you for you help. I believe we are almost there.
      This is a picture for reference.
    • Karthik R
      Administrator
      Excellent! Gald this works. Please feel free to mark the most appropriate answer as 'Is Solution' to benefit the community.
      Thank you!
      Karthik
Viewing 5 reply threads
