August 3, 2019 at 3:23 pm
Fabricio1
SubscriberDear Mr
I was able to produce a rigid body immersed in fluid and make it move in the -x direction but after the simulation progresses by various time increments it stops by error after 1.2 sec. Can you tell me if I need to improve the mesh around my body or other advice to address this issue?
Best Regards
August 3, 2019 at 4:41 pm
SubscriberIs it modeled in Fluent or CFX?
I recommend you investigate the Immersed Body method available in CFX.
August 3, 2019 at 7:41 pm
Fabricio1
SubscriberI am using CFX the body has to be semi-immersed so it can create a wave by moving like a wedge the way it is used at Kelly Slater's wave pool,. In that case the immersed body can be used?
August 3, 2019 at 9:53 pm
SubscriberKelly Slater's wave pool is awesome!
I don't know if the CFX immersed body works with a free surface, you will have to read the documentation.
August 4, 2019 at 8:49 pm
Fabricio1
SubscriberDear friend
Are you interested in solving this problem with me?. I already can create a typical wave pool and can create a wave generated by a moving sphere and can simulate a wedge type body moving semi submmersed. But the simulation stops after 1,2 sec and it would be necessary to accelerate this body up to 4m/s so i need 10 sec of simulation. Any sugestions other than the immersed body?
August 4, 2019 at 9:49 pm
SubscriberDear Fabricio,
I have been learning Fluent, and never used CFX. I have not yet built a VOF model, and will do that one day this year, but I'm busy with an airflow model right now.
Good luck!
August 4, 2019 at 10:16 pm
August 5, 2019 at 10:22 am
Ansys EmployeeWhy does it stop? Does it fail, or did it just run out of time steps?
August 5, 2019 at 9:17 pm
Fabricio1
SubscriberIt says meshing folding problem
August 7, 2019 at 8:31 pm
Fabricio1
Subscriberthe program inform meshing folding problem
August 8, 2019 at 1:49 pm
Ansys EmployeeIf you look at the last data set how fast does the object move, and if you compare it's speed across a cell with the time step how does it look?
August 8, 2019 at 8:12 pm
Fabricio1
SubscriberI tried both using a rigid body with 1m / s2 acceleration and also a program-defined body (without defining faces previously) and putting a movement defined by 1m / s2 acceleration. In either case the body moves for just over 1 sec and reports error code 2. The movement is noticeable. I was more successful in moving a submerged sphere, which moved longer and could see the wave generated by the movement, but it also stopped by an error after a while. I have been more fortunate in leaving my body still and accelerating the water around him with one face defined as inlet and other as outlet.
August 8, 2019 at 10:12 pm
Fabricio1
SubscriberIf you want you can give me your email and I will send you the template via gmail
August 9, 2019 at 1:14 am
SubscriberANSYS staff do not open models (I am not staff).
If you use a time step that is 10 times smaller, will that let the simulation continue further?
Do you have to keep the body accelerating? What if you transition from acceleration to constant velocity? Would that keep the wave going then use the profile of the floor to shape the wave?
August 9, 2019 at 7:12 pm
August 12, 2019 at 12:15 pm
Ansys EmployeeWhich suggests that the moving mesh wants a smaller time step: what happens if you drop the time step by a factor of 10 as Peter suggests?
August 12, 2019 at 12:29 pm
Fabricio1
SubscriberI am trying a mixed approach by making the rigid body moves at 2m / s and making the water moves at 4m / s and using a time increment of 0.0001sec. In addition I activated the surface tension and increased the atmospheric pressure to 3 atm. Let's see how it goes;
August 14, 2019 at 9:16 pm
Fabricio1
SubscriberIt seems that I have achieved a satisfactory solution by combining a 4m / s velocity of water flow with the movement of a solid using the displacement of its mesh with a sinusoidal function only in the -x direction. With that I was able to run several steps of time and generate an incipient wave that I will now refine.
August 21, 2019 at 8:53 pm
Fabricio1
SubscriberThis was the best modeling integrating a water flow and a sinusoidal motion in the -x direction only. Unfortunately, you can't simulate the Kelly Slater's wave pool perfection. When I get the body to move alone
at a given speed or acceleration the time increment needs to be minimal and weird effects appear as the water is forced out of inertia some vertical water jets are generated and prevent further analysis. Any additional tips?
August 22, 2019 at 10:04 am
Ansys EmployeeYou do know you can create an isosurface of VOF at (for example 0.5) to show the free surface? Have a look at the local flow patterns and mesh, there's usually a reason for weird results.
November 19, 2019 at 12:06 pm
Jaredoac
SubscriberHi Fabricio,
I am learning Fluent in order to develop this kind of projects. If you want, we can try to improve the models together.
My email is jaredoac@gmail.com
2688
2130
1349
1136
461
