September 25, 2018 at 3:00 pm
ft19
Subscriberhello,
I would like to pass from a circle of 2mm radius to one of 1mm radius. can you explain me how can I do this? I want to use Fluent.
thank you so much
September 25, 2018 at 3:04 pm
Keyur Kanade
Ansys EmployeeCan you please explain your problem in details. If possible please insert some image of model or sketch.
Keyur
September 25, 2018 at 3:13 pm
ft19
SubscriberDesign 1: circle/annulus with a radius of 2mm
design 2: circle/annulus with a radius of 1mm
I want to pass from the design1 to the design2 using fluent
September 25, 2018 at 3:16 pm
Keyur Kanade
Ansys EmployeeIf I understand correctly, you want to change geometry dimension. You can define this dimension as parameter in Design Modeler or SpaceClaim.
Please do following steps.
Please use workbench.
Create geometry in Design Modeler.
Define geometry parameter for desired dimension.
Mesh using WB Meshing.
Then solve it in Fluent.
Now on workbench project page, you can change parameter value and just update the system by right click. This will update all cells.
Keyur
September 25, 2018 at 4:46 pm
ft19
SubscriberI want to change in a dynamic way the dimension. I would like to have expansion and shrinking of the circle as a loop. I want to set a time and see the motion from design 1 to design 2 and then again design 1.
September 25, 2018 at 4:55 pm
Keyur Kanade
Ansys EmployeeSo you want to use moving deforming mesh like given in following.
Keyur
September 25, 2018 at 5:01 pm
Keyur Kanade
Ansys EmployeeThere are many macros. You may want to check following one example.
#include "udf.h"
DEFINE_GEOM(parabola, domain, dt, position)
/* set y = -x^2 + x + 1 */
position[1] = - position[0]*position[0] + position[0] + 1;
Keyur
2524
2064
1279
1096
456
