October 7, 2018 at 1:26 am
knnn
SubscriberHello,
I am simulating a linear induction motor, but when I assign a box band around the primary, Maxwell is saying that there are moving parts that touch stationary parts even though that is not true at all. Also it is saying there is an issue with the geometry band. Why would this be that case?
- Maxwell, HFSS or Q3D?
- Error
2600
2088
1319
1108
459
