April 18, 2022 at 6:26 pm
axt5488
SubscriberHello everyone
I am trying to model a gaussian laser heat source as a moving volumetric heat source. When I tired to compile the UDF I received an error and a warning below:
Source5.c(19,1): warning: type specifier missing, defaults to 'int' [-Wimplicit-int]
DEFINE_SOURCE(heat_source, c, t, time, dS, eqn)
Source5.c(19,14): error: expected ';' after top level declarator
2 warnings and 2 errors generated.
scons: *** [Source5.obj] Error 1
scons: building terminated because of errors.
/*Here is the UDF*/
#include "udf.h"
#include "math.h"
#include "metric.h"
#include "sg.h"
#include "sg_mphase.h"
#include "mem.h"
#include "sg_mem.h"
#include "flow.h"
#include "unsteady.h"
#define A 0.24 /*Absorption coefficient*/
#define P 400 /*Laser Power*/
#define re 0.1 /*radius on top*/
#define ri 0.2 /*radius on bottom*/
#define zi 0.05 /*cone length parameter lower z axis*/
#define ze 0.1 /*cone length parameter upper z axis*/
#define v1 1200 /*laser velocity*/
#define v2 1200 /*laser velocity*/
#define pi 3.1415;
real coord[ND_ND];
real x, y, z;
C_CENTROID(coord, c, t);
real xC = 0, yC = 0, zC = 0; /*initial position of the heat flux*/
real t0 = 3; /*the time that the heat flux is stationary*/
real time;
real H = zi - ze;
real r0;
r0 = re + ((ri - re) / H) * (z - ze);
real Q0;
Q0 = (6 * A * P) / (pi * -H * ((re*re) + (re * ri) + (ri*ri)));
real Q;
Q = Q0 * exp(-1 * (((x - v1 * time) ^ 2 + (y - (v2*time)) ^ 2) / r0 ^ 2);
if (time < t0)
x = xC;
y = yC;
z = zC;
dS[eqn] = 0.0;
else
time = time - t0;
x = xC + v1 * time;
y = yC + v2 * time;
z = zC;
dS[eqn] = 0.0;
return source
Is anyone can figure out how can I solve this error and warning?
April 19, 2022 at 4:32 pmRob
Ansys EmployeeThe error is linked to
and implies there's a ";" either missing or where it shouldn't be. Typically the error is triggered for the line after the code mistake. Whether that'll fix both errors is a different question.
2616
2098
1323
1108
461
