August 19, 2019 at 2:12 pm
Ansan
SubscriberWell I was running my simulation in ANSYS FLUENT via spruce (supercomputer), parallel processing. My simulation was smooth and so far I know had no problem but once I tried to save cases and data I got an error as shown:
Error at Node 0: PRF_all_to_one_csend_real: out of memory. The fluent process could not be started.
Error: Error writing "simulation.dat".
Error Object: #f
How can I resolve this issue? Is it possible to save this case without any error?
August 20, 2019 at 9:43 am
Ansys EmployeeCheck disc space on the system and where you're saving the file. Also check RAM usage, the error may imply you've run out of RAM when trying to save.
Can you try a small mesh to see whether it's case or system dependent?
August 20, 2019 at 1:59 pm
Ansan
SubscriberThank you sir. I don't think its a problem with a mesh because earlier I had ran this simulation and had no problem. Also, I checked my disk space and found I have plethora of space. Like you said I think its a problem with RAM. Could you please tell me how to check RAM usage in spruce (supercomputer), parallel processing?
August 21, 2019 at 9:31 am
Ansys EmployeeIf it's UNIX or LINUX you can use "top" on the head node, if it's Windows I have no idea. Can your IT department check the logs?
2524
2066
1279
1096
457
