March 2, 2022 at 9:32 am
Xicheng1
SubscriberHi everyone,
I recently updated Fluent from 2019 R2 to 2021 R2 as the new supercomputer in our school only supports the latest version.
I also update my case as it can be run by Fluent 2021 R2. I tried 10 cores parallelization in my local machine and it works perfectly. When I upload it to the supercomputer and run with 128 cores, it returns errors like these:
March 2, 2022 at 12:02 pmRob
Ansys EmployeeStaff are not permitted to open attachments, please re-post the log (if you need a couple of posts that's fine).
March 2, 2022 at 12:37 pmMarch 2, 2022 at 1:20 pmRob
Ansys EmployeeTry on around half the number of cores. The error is system side, but could be a number of causes. File corruption is one possible, then we're into network hiccups and more IT related issues.
March 2, 2022 at 1:59 pmXicheng1
SubscriberThanks, Robs Yes, I tried to use 64 cores and it returns the same error.
The file is fine when I run it on my local machine using the same command, it works perfectly.
I also forward this issue to the staff of the supercomputer team and wait for their reply.
March 2, 2022 at 2:16 pmRob
Ansys EmployeeNot sure then. Looking in more detail 800k cells won't scale all that well beyond 8-16 cores depending on physics as the data transfer cost can outweigh benefit of the extra cores.
Viewing 5 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
459
