January 7, 2023 at 11:10 am
Dubey92
SubscriberI am running a solidification/melting simulation with "Non-Iterative Time Advancement" with fixed time step method. I am running it on a Linux cluster with multiple cores. The simulation runs fine for first some time steps but then stops with the error:
DF5-DIAG: Error detected in HDF5 (1.10.5) MPI-process 0:
#000: H5F.c line 444 in H5Fcreate(): unable to create file
major: File accessibilty
minor: Unable to open file
#001: H5Fint.c line 1509 in H5F_open(): unable to open file: time = Sat Jan 7 13:09:29 2023
, name = 'D:PowderParticlesSLM - SmallParticleBed_filesdp0FFFFluentFFF.1.gz-2-01000.dat.h5', tent_flags = 13
#002: H5FD.c line 734 in H5FD_open(): open failed
major: Virtual File Layer
minor: Unable to initialize object
#003: H5FDsec2.c line 346 in H5FD_sec2_open(): unable to open file: name = 'D:PowderParticlesSLM - SmallParticleBed_filesdp0FFFFluentFFF.1.gz-2-01000.dat.h5', errno = 24, error message = 'Too many open files', flags = 13, o_flags = 242
Error at Node 0: HDF Error occurred! at IO/Hdf/src/HdfFile_impl.hpp:151 during a call to HDF5 library function H5Fcreate
0: mpt_accept: error: accept failed: Too many open files
Same simulation runs fine when I run it on a windows work station.
Any help is much appreciated. Thanks
January 9, 2023 at 9:17 am
DrAmine
Ansys EmployeeProbably missing libraries or Access violation. Which Linux OS are you utilizing? Which Ansys Version?
Refer to this 2.1. Required Linux Libraries by Product (ansys.com) to check any missing libraries.
January 10, 2023 at 6:49 am
Dubey92
SubscriberHi DrAmine. Thanks for your reply. I am using ANSYS 2020R2 on Ubuntu 20.04. I made some changes in the boundary conditions and it worked. But I am not sure if it will work always and there is some other issue.
January 9, 2023 at 11:19 am
Ansys EmployeeTo add, the h5 format can fail due to parallel hardware issues. If you switch the file I/O in preferences to legacy it'll revert to .dat.gz which is slower but can be more stable.
January 10, 2023 at 6:50 am
Dubey92
SubscriberThanks for your input Rob.
2524
2066
1279
1096
457
