November 14, 2018 at 10:26 pm
dlee0041
Subscriberhello
I am receiving the error message
"An error occurred inside the FATIGUE module: Invalid or missing stress life curve."
I believe I need to add the alternating stress mean stress into my Engineering data source as an material property for my material. I do not know the additional components that make up this property. I am working with the material Al 7075 t6. What properties am I missing.
I am also receiving an error message
" During this solution, the elapsed time exceeded the CPU time by an excessive margin. Often this indicates either a lack of physical memory (RAM) required to efficiently handle this simulation or it indicates a particularly slow hard drive configuration. This simulation can be expected to run faster on identical hardware if additional RAM or a faster hard drive configuration is made available. For more details, please see the ANSYS Performance Guide which is part of the ANSYS Help system."
November 15, 2018 at 1:12 am
Sandeep Medikonda
Ansys EmployeeHi,
Yes, you would need the materials S-N Curves. I happen to have this material, you can digitize from this image:
In addition to this, you might just need the Tensile Ultimate Strength, which you should be able to get from a quick search.
Sandeep
Best Practices on the Student Community -
November 15, 2018 at 3:30 am
April 27, 2020 at 5:00 pm
chibennett
SubscriberSandeepMedikonda,
I am working on a school project that requires the use of AL 7075. Your SN curve for AL 7075 is the only one I can find. Can I please know your source for this? I would like to be able to give appropriate citations for this information.
Thank you,
Michal
April 27, 2020 at 5:03 pm
chibennett
I am working on a school project that requires the use of AL 7075. Your S-N Curve for AL 7075 is the only one that I can seem to find. Could you please tell me your source for this information? I would like to give appropriate citations for this data.
Thank you,
Michal
Sandeep
July 14, 2022 at 10:08 am
shubhammevada3112
SubscriberHow to digitize the data from the image? I need this exact for my analsys but seems I can't find the cycles and stress accurate. Please help ASAP
2146
1357
1144
462
