April 29, 2023 at 6:29 am
Bahar Gültekin
SubscriberBOYU 150 mm, KALINLIĞI 10 mm VE ENİ 100 mm OLAN BİR KİRİŞE 40 KİLONEWTON MOMENT UYGULANIRSA MAKSİMUM NORMAL GERİLME NE OLUR
May 2, 2023 at 11:26 am
Ashish Khemka
Ansys EmployeeTranslated version:
WHAT IS THE MAXIMUM NORMAL STRESS IF 40 KILONEWTON MOMENT IS APPLIED TO A BEAM WITH 150 mm LENGTH, 10 mm THICKNESS AND 100 mm WIDTH?
May 2, 2023 at 1:23 pm
Armin_A
SubscriberHi Bahar,
It depends on the axis about which the bending moment is applied. Please see the reference below for analytical calculation of normal stresses generated by bending moments:
https://eng.libretexts.org/Bookshelves/Mechanical_Engineering/Mechanics_of_Materials_(Roylance)/04%3A_Bending/4.02%3A_Stresses_in_Beams
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5204
3281
2459
