November 4, 2023 at 9:39 am
hagos alem
SubscriberHello dears, I need to simulate the simple distillation process containing water, ethanol, stillage, and air using fluent. so which approach of multi-phase model should i use for best computational time and accuracy?
regards, -
November 9, 2023 at 12:21 pm
Prashanth
Ansys EmployeeHi,
since it is a mixture, you can think of using a partial pressure driven mass transfer model. Fluent has some options. You can read through this section: 14.7.7.2. Equilibrium Models
November 10, 2023 at 7:52 am
hagos alem
SubscriberThank you sir, I couldn't get the referance and could you please make it free accessed?
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
