3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
multi converter of neutral cad file formats not working
    • ebru akcan
      The "convert.exe" application inside the spaceclaim installation folder was used for multi-file conversion. but now it doesn't work unfortunately. why could it be
    • Charudatta Bandgar
      Forum Moderator
      Hello ebru akcan
      Can you please elaborate on the issue, I am not sure if I understand correctly. In the meantime, I will look for more information on this, if there is any.
      Regards.
      • ebru akcan
        Charudatta Bandgar There is "C:Program FilesSpaceClaim 2017.2Converter.exe" application in spaceclaim installation folder. In previous versions, with this application, we used to add different types and especially large cad files (eg 10 x 300 megabyte stp files, 20 x 100 megabyte parasolid files, 15 x 200 megabyte igs files) and convert them to scdoc or another format. Usually when the computer is idle We were using , so the files we needed were ready when we arrived .Now I wanted to try this application but I couldn't run it. It waits for a long time and gives the error in the picture (conversion process may have become unresponsive). I tried many times with different folders and files. The result is the same.. My system is win 10 x64, 8 gb ram, i7 processor
      • ebru akcan
        Charudatta Bandgar http://help.spaceclaim.com/2018.0.0/en/Content/Importing_and_exporting.htm
        this link has an explanation.
