August 29, 2018 at 7:04 pm
jesseahlquist
SubscriberHi,
I've been tasked to simulate the flow of water vapor, air, and Gas X (doesn't matter what) through a cold reservoir. The goal of this setup is to demonstrate the condensation of Gas X over a period of time 't', while the rest of the flow passes up and out of the assembly. The final goal is to be able to measure the final volume of condensed liquid in the reservoir.
I am interested to know if this type of simulation is possible in FLUENT. If so, can people provide any tips, past experiences, and point me to relevant resources to educate myself on how I can go about this task.
August 30, 2018 at 5:49 am
seeta gunti
Ansys EmployeeHello,
We have a video tutorial on evaporation/condensation process of boiling liquid using CFD in our You tube channel :'ANSYS FLUENT & CFD SOLUTION".
Please watch the below video.
Hope you will get help from the above videos.
August 30, 2018 at 6:33 am
DrAmine
Ansys EmployeeDoes the condensation happen on the wall or bulk condensation is expected to occur?
August 31, 2018 at 10:31 pm
jesseahlquist
Subscriberabenhadj,
Simple condensation on the wall, would be sufficient.
September 1, 2018 at 6:16 am
DrAmine
Ansys EmployeeIn that Case is the Phase Change concentration driven ans you can usevthe simple Eulerian Wall Film Model to Model (Not to resolve) the condensate of vapor at Wall. -
September 14, 2018 at 7:57 pm
jesseahlquist
SubscriberAbenhadj,
What do you mean when you say, "...model and not resolve the condensate vapor at the wall?"
Essentially, at the culmination of the simulation I need to measure the total volume of condensed volume of species X. Would this be possible given your advice?
Additionally, reading online I saw these comments on the EFM:
Ideally the model would be able to simultaneously condense both water and species X. If this is saying it cannot be condensed then should I use the Evaporation/Condensation Model?
September 17, 2018 at 4:23 pm
Ansys EmployeeHe's on holiday.
Looking at the manual section you'd need the Evaporation-Condensation model, but you'd still need R19.2 for that as prior to that release you can only use one phase change mechanism. I'd advise checking the wall film in R19.2 too as that may also have been upgraded in the mean time.
September 18, 2018 at 3:24 pm
jesseahlquist
SubscriberThanks for the update.
As I am using an Academic Student License where the 19.1 release is newest release, that means I won't be able to model this yet.
Do you know when this new release would become available for students?
2524
2066
1279
1096
459
