multi-physics coupling
    • HB Z
      I wonder if workbench can be used under Linux to run multi-physics coupling
    • Bill Bulat
      May I trouble you for a description of your application and the multiphysics coupling you want to achieve (what kind of engineering disciplines are participate in the coupled field response. For example, structural displacement/stress/strain, fluid flow (convective heat & mass transport or forces), heat transfer, electric conduction (Joule heating), electrostatic forces (MEMS), piezoelectric coupling, piezoresistive coupling, magnetic and/or Lorentz force induced motion, motion/changing magnetic field-induced electric current)? There are different procedures for different kinds of coupling, and there may be OS limitations to some of them. I think all of them support LInux now but I'm not 100% certain... I may have to double check that.
      Best regards,
      Bill
    • HB Z
      Thanks for your reply, I want to use Workbench for fluid-solid-thermal two-way coupling, and I want to run with the tui command like Fluent without displaying a graphical interface.
    • HB Z
      I also want to ask a question why the data exchange between the fluent module and the transient structure module is slow when I am doing fluid-structure interaction.
Viewing 3 reply threads
