August 1, 2019 at 7:21 am
August 1, 2019 at 8:49 am
Naresh Patre
Ansys EmployeeHello M1_Garand
Though it is not possible to select multiple locations from the list, you can achieve the same by editing the expression. If you click on the plane in location field you will get the location path. See below image which gives the location path of "Plane 1".
Similarly, if you have another plane, you can click on it to get the location path.
Now to specify multiple locations, specify all the location paths separated by a comma "," in the location field. See below location path which contains path for 3 planes - Plane 1, Plane 3 and Plane 4.
["@@/Study/Plane:Plane 1", "@@/Study/Plane:Plane 3", "@@/Study/Plane:Plane 4"]
See below image showing this combined location path and the contour results plotted for the 3 planes in a single result object.
August 5, 2019 at 2:10 am
dj.huang
SubscriberHello Naresh Patre
According to your comments, I have already obtained the results I need. Thank you for your help.
3778
2587
1831
1244
598
