Ansys Products
Ansys Products
Multi-step analysis, External pressure in static analysis
    • nastyashustic
      Question about multi-step analysis.
      I have two import pressures, one acting after the other in static, i.e. I apply one pressure, the geometry deforms from it. Next, a second pressure is applied to the deformed model and I look at the deformation at the end.
      I do 2 load steps simply.
       Please let me know if I'm doing the right thing.
      The pressures come from the CFD calculation. After the first application of pressure, I pass the deformed model to the calculation of aerodynamics, then they give me new pressures and I apply them.
    • Chandra Sekaran
      Hi, is the questions if it is OK to apply 2 different pressures in 2 different load steps? Can you elaborate on the question?
    • gaxone gaxone
      I had the similar problem, however I didn't have to start from fresh with the mesh.
        rolling ball 3d
