Multi-tubular reactor
    • hbachiri
      I want to simulate a multi-tubular reactor.
      The first step was to simulate only one tube of this multi-tubular reactor to validate the model. (1st simulation)
      Then I will need to simulate the whole reactor. (2nd simulation)
      Is there a way to use the results of my first simulation in my second simulation? as this will allow me to gain time.
      I know normally I can connect results from one fluent component to another fluent component, but in my case the results need to be affected to the tubes only, and I don't know how this can be done.
      I would appreciate any hint on how I can do it and how feasible is it.
      Thank you in advance
    • Nikhil Narale
      You can write and read interpolated data. Have a look at this section of the Fluent User's guide: 3.20. Mesh-to-Mesh Solution Interpolation (ansys.com)
      If you are not able to access the link, refer to this forum discussion: Using Help with links (ansys.com)
      You may also want to have a look at this video tutorial:
      Thank you,
      Nikhil
