MultiBlock Meshing
    • puh69
      I have a NASA CRM Multiblock grid, which has 5 zones and was wondering if there's any instructions as to how to setup something like this in Fluent.
      Thanks,
      Pierce
      If you've got the mesh into Fluent you may need to label some surfaces otherwise set up is "normal". If the surface labels are too coarse (ie a cube has only one surface label) look Domain-Zones section of the ribbon.
      There are tutorials if you click on help, but they tend to assume the mesh has imported and has suitable boundary names assigned.
