April 2, 2022 at 2:00 pm
Jake_Bils
SubscriberHi All,
Been fiddling around with this for a while. The experimental data I am basing this off is already true stress/strain (tried converting just in case to no avail). I have yet to find any modelling using this material, inputting the values is difficult with a material with such extreme strain hardening. Due to the initial negative slope in the plastic region, I have to start the value inputs from a larger strain than all examples I have seen, and is far from the yield strength. Below is the data I am gathering and my multilinear isotropic inputs.
April 5, 2022 at 4:36 pmJohn Doyle
Ansys EmployeeMISO is intended for modeling ductile metals, not plastics. Your best bet is to try using the Three Network Model (TNM) option intended for thermoplastics. Please refer to Section 4.6.12.1 of the MAPDL Material Reference guide along with the related references.
See also Section 6.1.9 for TNM curve fitting tips
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2656
2120
1345
1118
461
