Multiphase modelling in chemical looping combustion
    • Wasim
      Hi, I m doing multiphase modelling between solid and gas which include heterogeneous reactions. I am using eulerian approach, I interpreted heterogeneous reaction error free but problem is there no decrement in reactant value and increment in product value after running simulation 2days n
      OK, if you work through the UDF (I assume that's what you interpreted) are any/all conditions met for it to do something? Where did you hook up the UDF?n
    • Wasim
      I hook my heterogeneous reaction udf in phase interaction tab in the place of arreheneous equation. am i doing anything wrong. I took first order reactionn
      Probably, otherwise it'd work. Check the phase/species IDs to make sure you're reacting what you think you are, there may be an example in the manual or online, I don't have anything I can share. n
Viewing 3 reply threads
