Multiphase Simulation
    • Sud
      How can we simulate the case just opposite of Cavitation process? Like, if a high speed aircraft moves through the thin air, then due to the low pressure near the body of an aircraft condensation happens. So, how can we simulate such situation considering an aerofoil as our moving body?
    • DrAmine
      If you are working with CFX you can use the Droplet Condensation Phase Change model. For Fluent if you have pure fluids then the Density Based Solver with Wet Steam can be used. Otherwise you just need to write a small UDF for the mass transfer.
