multiphase steam jet pump (ejector) (mixture model)
    • Jabaly
      Dear All
      I'm trying to apply a multiphase model (mixture model) on an ejector ( as a steam jet pump). so I am trying to validate a paper about this topic. where,
      1.The primary fluid (water) with flow rate Q0 and high-pressure P0 is accelerated through nozzle and obtained subsonic speed results in a low-pressure PS (vacuum) at the outlet section of the nozzle.
      2.
      The secondary fluid (air, with flow rate QS) is entrained and accelerated into the mixing chamber.
      Note#1:
      Paper title: Numerical study on mixing flow behavior in gas-liquid ejector
      https://doi.org/10.1007/s42757-020-0069-z
      I applied all Bc's from that paper, Which are:
      1.Mixture model –noslip velocity –implicit-without phase interactions
      2.Steady state
      3.axi-symmetric
      4.Air-water (mixture)
      5.K-e model (turbulence)
      6.V water =3m/s …………..nozzle
      7.V air=3m/s  …………….domain
      8.Outlet= atm pressure
      9.Methods= coupled
      10.Default properties for materials (water and air)
      The problem is:
      There is a problem with the behavior of water when I get the volume fraction results. as you see in fig (A1 to A5) the water flow like a transient behavior ( 200 iterations is different from 400 iterations and so on).
      Note#2: I applied steady-state, not transient
      I think I need to apply phase interactions between water and air. but I don't know what is good interaction between them that I should apply to get the volume fraction as the paper (figure B).
      may you help me to solve this problem?
      Thanks a lot
      My result (figure A)
      paper result (figure <img src=">
    • DrAmine
      As we cannot read any paper can you please double check your boundary conditions? Are they accounting for any other thing like mass transfer from water to water-vapor in air? Moreover from your picture there is clear stratification from the other pictures a sort of diffusion which tells me that diffusion force is missing in your case.
      Please also post the velocity field at 1200 iterations.
    • Jabaly
      Thanks for your reply.
      plz see attached link (pdf file), this is a presentation about that paper. It will give us a good and quick view of the ejector.
      The link:
      https://drive.google.com/file/d/1mdSTm3Zi1Kol20Ib0K3u_EXg0n6BxXAf/view?usp=sharing
      and yes you are right, the flow looks like stratified flow in my result, and I need to apply something like ( evaporating -condensation interaction) or ( cavitation) , I should reach to bubble flow as the paper.
      but you know, evaporating -condensation interaction can be used when you have one fluid like water, and then convert liquid to vapor.
      but in our system we have air-water mixture, so what is the interaction that I can apply in fluent ?!
      Note#1: the paper does not mention anything about the interaction between water and air.
      Note#2: you can see the velocity and pressure  counters, also velocity profiles
    • Jabaly
      yes sure, plz see attached photo for the velocity contours and profiles, and this link (pdf file), this is a presentation about that paper. It will give us a good and quick view of the ejector. also, you will find the velocity profile in slide #17.
      The link:
Viewing 4 reply threads
