December 5, 2019 at 6:20 pm
donovankwong
SubscriberHi,
I have a magnetic transient model where I have multiple coils with a single sheet terminal inside them such that the coil is a self contained closed loop. All the terminals are assigned to a single AC (time domain) voltage winding excitation.
When defining the excitation:
- Are the resistance and inductance values for a single coil or the sum of all the coils?
- Is the voltage defined per coil, or in total?
- What exactly is the meaning of the number of parallel paths?
In the results:
- Is the current the total going through all the coils, or for each coil?
Thanks in advance for your help.
December 9, 2019 at 7:38 pm
mbeliaev
Ansys Employeecoils are connected in series. RL also added in series.
Voltage defined per winding. Winding may contain multiple coils
for more info please refer to the help.
Maksim
- Maxwell, HFSS or Q3D?
- Error
5162
3251
2443
