March 8, 2022 at 6:29 pm
pierre-luc.piveteau
SubscriberHello,
I'm running Lumerical FDTD on my university on-premise cluster, which uses Slurm as a job scheduler.
I would like to run multiple simulations, either sequentially (parallel computing) or at the same time (concurrent computing), in case of sweeps. I'm following the procedure described on your portal : Running simulations on your cluster – Lumerical Support (copying all files from the sweep to the cluster and running simulations from here).
Why is the code syntax I should use in my Batch submission script to execute all simulations (either sequentially, or simultaneously, based on my license capabilities of course).
I tried the following command line in my batch script:
"srun fdtd-engine-impi-lcl -logall -fullinfo simulation_1.fsp simulation_2.fsp simulation_3.fsp"
but it submits only simulation_3
Thank you for your help !
Have a nice day!
March 11, 2022 at 8:05 pmViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2662
2120
1349
1130
461
