February 9, 2022 at 1:31 pm
najafi
SubscriberHi . I want to have parallel processing with making connections between different computers. The software is Ansys Fluent 18.2. I made the same user name and passport for all computers and I installed the MPI software from the DVD package. I shared the same directory in each system and I made a txt file that mentioned all IPs of the computers. But, when I lunch the fluent, a command prompt window will be opened and I should write the user name of the computers. After that, I should write the password but I can not write it because my keyboard does not work. I can just click enter. Could you explain where is the problem? I have attached the window to this message.
Thank you
February 9, 2022 at 1:49 pm
System
SubscriberThis discussion was created from comments split from: Using multi cores/processors in System Coupling.
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3930
2649
1865
1272
610
