July 4, 2023 at 5:54 am
Fakhriyya Mammadova
SubscriberHello everyone. I wonder if it is possible to set up two or more sources in Ansys lumerical fdtd for topology optimization. I am trying to do that but it seems like one of the sources does not work, so the device acts like one source device instead of two sources. -
July 4, 2023 at 7:45 pm
Niki Papachristou
Ansys EmployeeHi Fakhriyya,
Even though lumopt was not built to work with multiple sources there are two ways to achieve your optimization. You can either co-optimize the performance of both inputs separately or can you have two input sources and if you name both ‘source’ the automated routines should work. However, if you provide us with more information on what you are trying to achieve we might be able to give you more guidance.
Niki
July 5, 2023 at 11:47 am
Fakhriyya Mammadova
SubscriberThank you Niki,
I am trying to design AND logic gate. I wanted to set both sources for 11 case and set transmission to 1 on the output. However, the transmission I obtain is close to 0. I am not sure why. I used two sources and named them both as 'source' just as you said
July 10, 2023 at 6:44 am
Niki Papachristou
I believe that what you are trying to achieve is more complicated compared to what you are asking for. Maybe it’s better go through FDTD simulations and try and understand why there is zero transmission through the system. Look at where the loss is coming from. However, it seems that simulating an AND gate you need to exploit nonlinearities. It might be worth searching on literature as well.
Kind Regards,
Niki
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7592
4440
2953
1427
1322
