November 11, 2023 at 7:39 am
jo9fin
SubscriberHi,Is it possible to add load muliplier in ansys mechanical? I will explain this with an example:I have a lot of different loads ie.PressureForceAccelerationI would like to multiply each of these loads by a value of 3 and then solve a non-linear analysis. Is it possible to do this using a single parameter p=3?(I do not want to use the load combinations function because this only combines the results of the analysis performed. For me it is essential to perform the analysis with increased loads. )Thanks in advance!TB -
November 13, 2023 at 3:34 pm
Mike Rife
Ansys EmployeeHi jo9fin
Are you asking if there is a way to change the values in the Graphical User Interface or just in the input file that gets sent to be solved? And which solver is being used (or which WB Analysis System)?
Mike
November 13, 2023 at 5:37 pm
jo9fin
SubscriberHi
Input file would be enough. Is there any APDL commad?
Thanks Mike
Tom
November 13, 2023 at 5:58 pm
Mike Rife
Ansys EmployeeHi Tom
There are several commands; search for 'scale' in the Mechanical APDL Help commands manual. There is FSCALE for scaling applied forces (at nodes). SFSCALE for scaling applied surface loads (pressures) on elements. Etc. mike
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3155
1688
1478
