May 17, 2023 at 9:46 pm
sagar
SubscriberWill the multipolar decomposition work for periodic BC? How Should I get the scattering cross-section for periodically arranged nanostructures? How will the substrate matter? Does anyone has done multipolar decomposition with periodic BC?
May 24, 2023 at 12:27 am
Guilin Sun
Ansys EmployeeSomehow this post was missed for reply.
It might work if you have a software for the decomposition.
For periodic structure, my long-time opinion is, it is not necessary to attribute the diffaction as scattering because only the 0th order is not scattering, higher orders are all "scattering". so you can evaluate the "scattering" by grating analysis. But more authors tend to use scattering terminology.
Without a substrate, you can quantify the scattering with only two monitors: in the reflection side and transmission side. All other monitors are not necessary due to periodicity. Please modify the analysis group.
If a substrate exists, the usual scattering loses its original meaning. However many people still use the "tradition definition" of scattering. I would recomend this example: https://optics.ansys.com/hc/en-us/articles/360042703313-Scattering-of-PSL-and-Cu-spherical-particles-on-a-substrate
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5414
3389
2471
1310
1022
