May 5, 2022 at 10:04 am
manelaero2020
SubscriberHi friends
Do multizone and sweep methods require an initial one body to be divided into five or 6 symmetrical bodies?
I have tried the two methods using one body but I have failed to create a mesh
the body is a cyclonic filter ( symmetric )
Thank you a lot
May 5, 2022 at 10:24 amRob
Forum ModeratorNo, but they do have requirements linked to how the bodies are shaped and/or connected. We've had good results with well refined poly meshes in Fluent so that's another option.
Viewing 1 reply thread- The topic ‘multizone _sweep method’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
