Preprocessing
Preprocessing
Multizone Blocking Decomposition failed.
    • ZIco
      Hi
      I am facing mesh problem and the generated mesh is not so smooth. i am using Multizone method with edge sizing and face mesh.
      Please check the attachment for reference and help me to generate smooth mesh.
      Regards
      Zico
      What are you trying to model?  The volumes don't look to be connected so you won't get a conformal mesh and sweep should work fine along the length of the pipes.
    • ZIco
      I want to model a drilling operation i.e to build a cutting transportation model through the annular fluid.  I have used the Sweep method too but it works only for wellbore not for drillpipe. Please check the attachment:
    • Keyur Kanade
      first of all get geometry connected with share topology.
      If there are any internal details, hex mesh may fail.
      then you can use tet mesh with inflation.
      Keyur
    • ZIco
      Dear Keyur
      I have tried all the option as per your recommendation but its still not working. Also i have tried face mesh and its not working.
      Here i am sharing my mesh details with geometry.....
      please verify it that i have done anything wrong here.
      Mesh
      Sectional view
      In joint section
      Mesh details, which i have done:
      Geometry Details, Which i have used:
      Regards
      Zico
    • Keyur Kanade
      i can see some tet mesh in your images.
      please seletct source and target faces while defining multizone.
      if multizone fails, you can also try sweep method.
      please check help document for sweep method.
      Keyur
    • ZIco
      Hi
      I have tried all your recommended options but its still not working (i.e in mesh face mesh option is not working).
      If i don't form new part then i find a good mesh, is it ok or not, i need your concern:
      cross-section of soild pipe:
      regards
      Zico
      Turn off all the local sizing and set the global values to be something sensible. Use a multibody part and turn off multizone. What happens?
    • regitasyali
      Hello, I am no expert and also new to this field but someone sent me this neat multizone meshing video tutorial and I hope this helps. Good luck!
      https://studentcommunity.ansys.com/thread/multizone-blocking-decomposition-failed-1/
Viewing 8 reply threads
