December 7, 2020 at 8:37 am
Manoj55
SubscriberI am trying to do all quad mesh on bolts so that it can behave properly for bolt pretension, but I am getting error of multizone decomposition failed.nI tried hex dominant method but the mesh generating with all quad setting is not good as requiredn -
December 7, 2020 at 8:47 am
December 7, 2020 at 9:28 am
December 7, 2020 at 2:05 pm
Rahul Kumbhar
Ansys EmployeeHere are some suggestions:nRemove if there is chamfer on the bolt headnUse small body sizing on these two bodiesnSelect the bolt end faces, bolt spacing face, basically all parallel faces as 'src/tagt selection'n
- The topic ‘Multizone Decomposition failed on Bolt’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
