February 22, 2022 at 11:08 am
diksha
SubscriberHi everyone,
I am trying to model air flow across blades. When I considered 2 blades, the multizone method worked well in Design Modeller. However, now when I add one more blade, the multizone method is failing. Please advise how this can be fixed.
February 23, 2022 at 10:19 amKeyur Kanade
Ansys EmployeeYou will need geometry decomposition for hex meshing." target="blank">
Please check following videos
Ansys Meshing: Decomposition for hex meshing:
Ansys Meshing: Meshing Methods:
Regards Keyur
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2564
2080
1299
1106
459
