November 8, 2018 at 5:56 pm
November 8, 2018 at 7:16 pm
tsiriaks
Ansys EmployeeHi josedjad ,
Try this,
close all ANSYS related applications
open CMD Prompt, then issue the following command (copy and paste the entire line)
move %appdata%ansysv192 %appdata%ansysv192.back
Does this help ?
Thank you,
Win
October 22, 2019 at 11:57 pm
cseavs42
SubscriberI had this same issue. Using this solution worked for me. Thanks for the help!
October 24, 2019 at 9:39 pm
tsiriaks
Ansys EmployeeWelcome, thank you for letting us know.
May 3, 2020 at 11:11 am
essbrennt
SubscriberThank you so much! Also worked for the newer versions. ex. just change v192 to v194.
May 30, 2020 at 2:20 am
anu575dix
SubscriberHi tsiriaks,
I am using ANSYS workbench 19 R2. I can see the app is open in my windows taskbar but it doesn't let me to actually open it.
I tried the method you suggested above but that didn't work. Could you please advice how can I solve this issue?
Thanks.
Anupam
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2630
2104
1329
1110
461
