Ansys Products
Ansys Products
My client machines cannot connect to server machine
    • Ahmed_Awwad
      Dear allnI have a problem with connecting client machines with server machinesnI installed ANSYS 2020 R2 on server machine and I installed Ansys license manager then I read ansys license file and it works well in the server machinenThen I installed ANSYS on client machine connected to the same network and I specified the server machine then tried to set user license preferences to 2020 R2 but I had the error message that I cannot connect to the server machine. Can you help me to solve this problemn
    • tsiriaks
      Check out this thread to see discussions about networking requirement for ANSYS licensingn
      We have Granta EduPack 2020 (Ansys licensing). Ansys license is installed and working. The ports 1055 and 2325 are open to the clients. Granta seems to install fine, but when we try to run the software, we see ""Your license could not be loaded. Please check your license settings, including license server configuration."https://us.v-cdn.net/6032193/uploads/N368XGOUMOUC/granta-license-not-loaded.pngWhat is seems to be the problem?https://forum.ansys.com/discussion/20095/granta-edupack-2020-licensing-question
      You will see that there are 2 different ANSYS licensing mechanism depending on ANSYS products. They require different ports to be open.n
