My fatigue crack simulation can’t be solved using SMART Crack Growth
    • ZHOO001
      “An error occurred inside the POST PROCESSING module.” shows up when I wanted to compute the number of cycles for crack propagation using SMART Crack Growth. I'm using 2020 R2 Workbench. The attached documents are the simulation file. It's just a 60 x 30 x 1mm plate containing a centered semi-elliptical crack
      Please help!
    • ZHOO001
      To add on, I already assigned Paris Law to the material as well as choosing "Yes" for SIF and "No" for J-integral. I also have turned on the crack face nodes
    • David Weed
      according to one of the warning messages, it appears that the simulation failed to solve to completion. The reason for the error and red lightning bolt upon post-processing is most likely because a result object is requesting data that is beyond the last successfully solved time value. I would suggest either deleting all result objects and re-creating them or set the time in the result objects to the last successfully converged time value. Also, I unfortunately am not authorized to view your project, but looking at the solve.out may reveal why the simulation failed to completely solve.
    • ZHOO001
      what do you mean ÔÇ£ last successfully converged time valueÔÇØ? Where can I set the time value ?
Viewing 3 reply threads
