3D Design
3D Design
My geometry is not visible in the graphics window in designmodeler
    • YektA
    • Aniket
      Does this happen with every geometry or a specific one? If happens with every geometry try resetting the AppData for the version that you are using. If this is happening for a specific model try importing the model in SpaceClaim and see if you can see it there.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
    • YektA
      nThanks for your answer, first of all this happens in every geometry and geometries do not open in spaceclaim.nn
    • Aniket
      So does appdata reset help?nFor resetting the appdata:nclose all workbench sessionsnopen %appdata%/Ansys (assuming that you are using windows)nrename v202 to v202_old (assuming that you are using 2020R2)nand recheckn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
Viewing 3 reply threads
