March 21, 2021 at 2:36 pm
Nutan7274
SubscriberI've given the input values in the setup section, but my model won't pop up in the result section.....
March 22, 2021 at 4:14 amKeyur Kanade
Ansys EmployeeI do not see any case read in CFD-Post. nPlease read the file. You can go through some tutorials for CFD-Post. nOnce you give values in set up, please run the case and then read that in CFD-Post. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1283
1096
459
