December 9, 2020 at 11:46 pm
Zhu
SubscriberMy model is a dissected aorta, where the ascending aorta was replaced by a graft. So my geometry has two parts (Graft and Aorta) and the connection was defined as bonded. I am trying to get the pre-stressed aortic model since the reconstructed geometry was under a diastolic pressure. nFirstly, in Static Structural, I apply a pressure load that equals to diastolic pressure (80 mmHg) and the simulation converged quickly. I exported stresses as text files, which were then imported as inital stress through External Data for another Static Structural analysis. I applied the same boundary conditions toghter with those initial stresses but the solution became unconverged during the first substep as a result of highly distorted mesh. I suppose that the pressure load would counteract with the imported initial stress so there should not be any highly distorted mesh? Anyone suggestions about this would be appreciated a lot!n -
December 10, 2020 at 11:25 am
Ashish Khemka
Forum ModeratornnCan you share a snapshot of your setup? Also, what if you do not apply pressure and just see how the model behaves with initial stress?.Regards,nAshish Khemkan -
December 11, 2020 at 10:15 am
Zhu
SubscriberHi akhemka,nThanks a lot for your reply! I have attached two figures showing my Setup and Analysis Settings. By the way, my mesh was generated in ICEM and imported through the FEM. nI tried to apply only the initial stress without the pressure load but the same error occurred, still in the first substep. Any further suggestions would be appreciated. nYours,nYunn
December 14, 2020 at 2:40 pm
Zhu
SubscribernIn case you haven't noticed my last posting.nYours,nYun -
December 15, 2020 at 8:57 am
Ashish Khemka
Forum ModeratornnThe error without pressure load indicates that the elements are distorting when the body relaxes from initially applied stress.Regards,nAshish Khemka
- The topic ‘My simulation became unconverged after importing initial stress’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
