August 12, 2022 at 7:21 pm
yuriporto
SubscriberHello guys.
I changed my computer and I have been struggling to get Ansys 16.2 - Workbenck Static Structural to work on the new machine.
I will summarize.
If I make any model (solid, beam or shell), with a very small number of nodes and elements, the model works, as you can see in the image below.If on that same model, I refine the mesh minimally, the model stops working. Introducing the following error.
In existing models and that 100% of the analysis has already been done on another computer, this problem also happens, if I change any load, for example.
I use this same version on other computers with similar or even better configurations than mine. I really don't know what to do!! Please help me! 😩
August 16, 2022 at 12:38 pm
Ashish Khemka
Ansys EmployeeHi,
Â
If you have the geometry then can you try recreating the model?
Â
Ashish Khemka
August 16, 2022 at 2:07 pm
Chandra Sekaran
Ansys EmployeeWhat license is being used? This information will be in the solve.out file. Also in the solve.out file do you see any error messages?
3311
2471
