Named expressions ERROR
    • kouassi.kouame
      Hello Everyone,
      I want to use named expressions to define a BC. In my case i have to impose liquid-phase and gas-phase massflox rate at inlet. I got this error :
      The expressions i try to use have the same unit as my BC. and he works when i want to compute it, i can see the value. But i can't use it as BC.
      The phase name is correct.
      Can someone help me ?
      Regards and Thanks
      Which model are you using?
      • kouassi.kouame
        The Eulerian model. I want to modelize gas/liquid separation and i have to impose a massflow condition with named expressions but this error appear when i want to impose the expressions. i use the 2020R2 version.
        Thanks
      There have been several changes to expressions over the last few releases, can you retry in 2022R2? Please post a screen grab of where you were trying to apply the expression, and the expression itself.
    • kouassi.kouame
      I can't have acces to the 2022R2 version.
      The expression depend on other expressions and report definitons, this is a screen of the expression
      I want to apply it here :
      As you can see it's not red so the unit is compatible but i got error when i click apply
      As I mentioned the extent of expression functionality has been evolving rapidly. Is the value positive or negative? What happens if you run for a couple of time steps with a fixed value, recheck the expression value and then try applying the expression?
Viewing 4 reply threads
