Preprocessing
Preprocessing
Named selection in Spaceclaim based on location
    • omkarjoshi
      I am trying to figure out if there is a way to select the facets for a faceted geometry based on location, e.g. selecting facets between X-corrdinates 9.9mm and 10.1mm to select all facets on a face that is located at X=10mm. It can be done in ANSYS meshing using worksheets, but is there any way to do this in Spaceclaim?
    • 1shan
      You could use 2 planes at X=9.9 and 10.1, split the faceted body along these planes and then create a named selection of facets between them.
      Regards Ishan.
    • omkarjoshi
      Hi Ishan,
      I think I should have been clearer, in fact I want to select all the facets lying on a surface to identify boundary condition as shown below. Your approach wont work there I suppose. Spaceclaim must have a way to choose the boundary based on its location as it would make things so much easier.
