Named Selections, Fluent Meshing
    • mengineerm
      Hello Everyone,
      i have a problem with transporting the named selections that i created in Design Modeler to the Solver.
      For example: I created a named selection called "Bridge" in Design Modeler which consits of 8 Faces. When i import the geometry to Fluent Meshing the named selections are transported correctly (at least it looks like that). But when i switch to the solution, the named selection gets splitted into the individual faces of which it consists. The faces then have names like this :
      1.   Bridge
      2.   Bridge-087
      3.   Bridge-110
      4.   Bridge-154
      And so on...
      It´s not a big problem but its annoying and it costs time to select all the different faces individually, so does someone know what i am doing wrong, or how i can fix the Problem so that i can transport the named selections to the solver correctly ?
      Thank you very much
      Regards
      Moritz
    • RK
      Hello Moritz,
      In Fluent Meshing, after you have updated the regions, you can create a journal file to merge such objects. In the "Update Regions" section of the workflow, right click and choose "Run Custom Journal".
      /meshing/objects/volumetric-regions merge "filename" bridge-* , NewName TypeOfBoundary y
      Replace the characters appropriately.
      Right click Update Regions and select add boundary type and you can add the boundary type.
