3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Named User HPC License
    • jgshin
      Hi all.
      I have two questions about named user license.
      1. How many cores are included in 'Ansys Discovery HPC Add-on License'?
      2. Discovery has limit number of cores? What is the maximum number of cores?
      Best Regards,
      Jugyeong Shin
    • Devendra Badgujar
      Forum Moderator
      Hi JUGYEONG SHIN
      When licensed for high fidelity solves, the solver license itself allows up to 4 cores to be used. If additional cores are desired, Discovery attempts to acquire the appropriate HPC licenses:
      • For subscription license users, the Ansys Discovery Ultimate CPU Core Extension (disc_ult_cpuext) allows use of additional cores.
      Discovery does not request HPC capabilities beyond the number of cores available on the machine. In the event of a shortage of HPC licenses, the solve proceeds using fewer cores, and you will be notified that Discovery cannot obtain HPC licenses.
      Regards.
    • jgshin
      Hello Devendra Badgujar
      'When licensed for high fidelity solves' means Refine Stage, right?
      Also, if then, what is the object of 'Ansys Discovery HPC Add-on License(Named User)'?
      'Ansys Discovery Ultimate CPU Core Extension for Named User' can take HPC license of floating license?? or only use Named User HPC license?
      Best Regards,
      Jugyeong Shin
    • Devendra Badgujar
      Forum Moderator
      Hello JUGYEONG SHIN
       - Yes correct, meaning higher mesh count.
       - HPC add-on allows Discovery to pull additional processor core. This add-on enables to access up to 16 local processor cores in total.
       - For floating license users, the HPC licenses are typically Ansys HPC (anshpc) or Ansys HPC Pack (anshpc_pack) licenses.
      And for (Named user)subscription license users, the Ansys Discovery Ultimate CPU Core Extension (disc_ult_cpuext) allows use of additional cores, not for floating.
      Regards.
    • jgshin
      Thank you for your reply, Devendra Badgujar
      I have one more question.
      How many cores are contained in a 'Ansys Discovery HPC Add-on License(Named User)'?
      You said that the maximum number of core is 16.
      If I have just one HPC Add-on License, then can I use 16 cores?
      Best Regards,
      Jugyeong Shin
      • Devendra Badgujar
        Forum Moderator
        JUGYEONG SHIN
        Yes the solver license itself allows up to 4 cores to be used and this add-on will enable an additional 12 cores so that you can use 16 in total.
        Regards
Viewing 4 reply threads
