Natural convection in a pressurized storage tank
    • Moussa
      I am currently modeling transient natural convection of a liquid inside a tank but my simulation doesn't converge using SIMPLEC algorithm as mentioned in the article.
      Do you have a gas phase present too? Mesh (and cell) quality and time step are more likely to be causing the problems. n
    • Moussa
      Thank you, RobnI'm simulating the liquid phase only (H = 1m, W = 1m), the time step = 1s, the mesh is fine but my problem is the energy residual.nnn
    • Moussa
      Results with the COUPLED algorithm, the simulation is turbulent, g = 9.81, the problem is symmetric and steady.nThank you in advance nThe results from the articlenn
    • Draxler
      Did you change the Residual values to a smaller number than the default? nMost youtube videos change them to 10-6 and I was doing that as well. For very simple geometries, this works, but for complex ones, I was also having a problem with converging. I changed them back to 10-3 and the solution did converge. nSmaller residuals lead to more accurate results as far as I know. But in my comparison of the 2, there was very little difference.nn
      Given the SIMPLEC has only done 140 iterations you may want to try running it on. Also note, the PBCS solver uses a courant number or time factor so may converge better if you've not adjusted any of the under relaxation defaults. n
    • Moussa
      Thank younThe energy residual is falling under e-11, for the sufficient convergence of the iterative solutions, they use e-10 for the energy equation and e-0u00035 for the other conservation equations.nThe results at the initial state (t = 0) are obtained from the steady-state calculation at ptank = 1atm ( temperature contours posted earlier), there is a big difference between the two algorithms.nResiduals using SIMPLEC algorithm in steady-state simulation.nn
      Which isn't converged. Try dropping the momentum under relaxation factor. What density model are you using?n
    • Moussa
      Thank you, Rob nI'm using the Boussinesq model, steady-state, k-epsilon, g = 9.81, the liquid is methane.nMomentum under relaxation factor = 0.1nThe problem is the energy residual dropping I think nWhen I use the COUPLED algorithm with momentum under relaxation factor = 0.1nnn
    • Moussa
      Any advice? Thank you in advance.n
      I'd be more worried about the continuity equation in the first case. Given PBCS uses a time factor I suspect that's why the convergence is better. Converge the first case properly and then compare the results. n
Viewing 10 reply threads
