nCode Surface Change (Polished,Ground..)
    • Louie Lou
      I try to change material surface from polished to ground, however no change when I run the simulation. Can you help me, please?
    • Daniel Shaw
      The Workbench integrated Ansys nCode DesignLife systems are designed to always read the material information from Engineering Data when a solve request is issued from within DesignLife, so any material changes made within the DL UI will be overwritten. You need to "break" the link to WB to enable DsignLife to use material data defined within the DL UI. This behavior is explained in the Intro to Ansys nCode DesignLife training course.
    • Louie Lou
      Thank you, sir. I have broken the 'material map from WB' and the analysis is solved
