December 10, 2020 at 3:19 am
doublehelix
SubscriberWhen we define a near field sphere around the simulated structure which was simulated in FEBI box. We can plot " NearPoyntingTotal" quantity on the near-field sphere. But why cannot we plot the 'real' and 'imaginary' parts of the "NearPoyntingTotal"? Real part of the "NearPoyntingTotal" is needed to calculate the outward power flow from the sphere and I want to evaluate that.
Also, can you please tell that how the "NearPoyntingPhi" and "NearPoyntingTheta" related to "NearPoyntingTotal" ? Because "NearPoyntingPhi" and ""NearPoyntingTheta" can be exported in real and imaginary components separately. I am attaching some values from actual simulation and I cannot understand that how NearPoyntingPhi and NearPoyntingTheta can be used to calculate NearPoyntingTotal ?
December 11, 2020 at 7:26 pmdoublehelix
SubscriberAny answer or comments?nDecember 16, 2020 at 11:10 amPraneeth
Ansys EmployeenThank you for reaching to us and we appreciate your patience.nNearPoyntingTotal is the magnitude of the NearPoynting quantity which is expressed in Spherical coordinate system (rho, phi and theta). Hence you will not be able to get the real and imaginary parts where as the NearPoyntingPhi and NearPoyntingTheta can be expressed in real and imaginary parts.nNearPoyntingTotal eqauls to square root of sums of squares of rho, phi and theta components of NearPoynting quantity.nAll the very best.nBest Regards,nViewing 2 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8806
4658
3151
1680
1470
