Discovery Import
Discovery Import
nearest item selection
    • Guillaume ANFOSSI
      I am looking for a method to select by script an element close to another selection.
      For example, in the case below, I would like to retrieve from a face selection (1) the selection of the nearest edge (2)
      Is it possible ?
    • Devendra Badgujar
      Hi GUICAD
      Let me check and get back to you on this.
    • Devendra Badgujar
      Hi GUICAD
      Closest Edge to Secondary Selection...Text
      active=Selection.GetActive()
      if active.Count:
       item=active.Items[0]
       hitPoint = Window.ActiveWindow.ActiveContext.GetSelectionPoint(item)
       if isinstance(item,IDesignFace):
        closest=""
        dist=float('inf')
        for edge in item.Edges:
         project=edge.Shape.ProjectPoint(hitPoint)
         measuredDist=(project.Point.Vector-hitPoint.Vector).Magnitude
         if measuredDist(<)dist:
          dist=measuredDist
          closest=edge
      Selection.Create(closest).SetActiveSecondary()
      This should provide the key API needed, but you may need to change based on your needs. Let me know if this what you are looking for.
      Regards.
    • Guillaume ANFOSSI
      Perfect, thanks !
Viewing 3 reply threads
